tgaertne's avatar
Mar 29, 2020
Daisy chain order
How does Orbi decide to daisy chain vs star network? I have my satellites set up in a way I wanted them to daisy chain. When I first set them up, they worked that way and now for some reason both satellites are reading off the main router.
  • Under Advanced Tab/Advanced Settings/Wireless Settings
    Try putting the remote RBS out at a farther distance to see if it will connect to the 2nd RBS.
    • tgaertne's avatar
      tgaertne
      Tutor
      3000 square feet. I am within 30 from one to the next. Where do I find spot to enable daisy chain?
      • FURRYe38's avatar
    • tgaertne's avatar
      tgaertne
      Tutor
      Ok. I found setting and it is enabled. I also tried to reboot. Still won’t daisy chain
