Marynel's avatar
Marynel
NETGEAR Employee Retired
Aug 06, 2018
Flexible PoE Switch with Power Upgrade Options - Blog
Do you need PoE In your Business? What is PoE, you ask? Well, it stands for Power-Over-Ethernet, which means that just by using one Ethernet cable, you can supply both the network connectivi...
  • BretD's avatar
    Feb 05, 2019
    Update Feb/5/2019:  The Extended range of upgradable power adapters for the Unmanaged PoE Switches - GS108LP GS108PP GS116LP and GS116PP are now available. Learn more about PoE from our Power over Ethernet Page.
    To purchase the new PoE power adapters please click the model numbers below.
    EPS90W
    Compatible with
    EPS130W
    Compatible with
    EPS200W
    Compatible with
    GS108LP
    GS108LP
    GS108PP
    GS108PP
    GS116LP
    GS116LP
    GS116LP
    GS116PP
    GS116PP
    GS116PP
ProSupport for Business
