TheDoctor165
Oct 03, 2022Aspirant
FS105 switch died
Hello:
I have a FS105 switch that just died (everything on it disconnects from the network after times ranging from 20 minutes to 24 hours or so until I unplug and replug it in). Connected a D-Link switch and the problem goes away so I am sure it is the switch. I am curious how long the FS105 lasted. I found a spec on it that the mean time to failure is 40 years or so. I am not sure when I bought it, but it is surely nowhere near that old - and yes, I understand mean time to failure does NOT mean it should last 40 years... still that seems a bit extravagant. Is there a way to find out the manufacturing date. It is far older than any receipt I kept for it.
I am finding my aging Netgear switches are failing regularly now, but my D-link switches, many far older, are still going strong. So, I am trying to track lifetimes... just curious.
#FS105
The MTBF (Mean Time Between Failures) is a calculated statistical number. Of course, it can give some ideas about the expected lifetime however. Some devices can last always "forever" while others can fail during warranty, after a few years, while some can last decades. Factors are the environment (temperature, humidity, condensation, power availability/continuity/voltage/overvoltage e.g during thunderstorms, user behavior like on/off cycles, and many more).
The MTBF number is used for risk of failure calculations of complete networks for example.
- TheDoctor165Aspirant
Any input on the manufacturing date or how to determine it?
- Marc_VNETGEAR Employee Retired
Kindly send me through PM the SN of your switch, I might be able to check with that. FS105 was release around 2000s.
HTH
