smoyerphd
May 21, 2016Aspirant
FS105v2 interop problems with gigabit switches and router
I'm seeing very poor performance when a FS105v2 is connected to a switch or router with gigabit ports. This is 100% netgear equipment. R7800 router <--> client: yields 235Mbps on speedtest.net ...
- May 29, 2016
NetGear support had no idea why this happens. Their suggestion was to file a ticket against the router.
I decided not to pursue this any further. I have a workaround which is to insert an extraneous GS305 so that I have 2x GS305 between my router and my FS105v2 (which I need due to some 100BASE-TX wiring). This works -- it's an annoying but cheap solution.
DaneA
May 26, 2016NETGEAR Employee Retired
Hi smoyerphd,
Any updates on your online case?
DaneA
NETGEAR Community Team
smoyerphd
May 29, 2016Aspirant
