gfranke
Oct 01, 2020Aspirant
Gigabit unmanaged switch not distributing signal to other ports
Trying to install a GS105v5 switch to extend my network. Powered up and have the internet input in Port1. Plugged two cables into Port2 and Port3 and they do not light up. No signal is being dis...
- Oct 22, 2020
Thanks to those who replied.
Turns out I needed a POE switch. Both output cables from the switch have to first provide power and data to VoIP phones. A non-POE switch won't work.
Thanks for the help. I learned something.
Gary
gfranke
Oct 07, 2020Aspirant
When I move the incoming cable from port 1 to port 2, port 2 lights up.
The other two cables are going to two different cubicles.
I returned the first unit thinking it might be defective and bought another. Same problem.
Thanks
Oct 07, 2020Guru - Experienced User
for 2 devices to have the exact same issue makes me suspect the cables or devices plugged in. but it gets more complicated becaues it works fine in port 2.
Does port 1 work with other devices plugged into it?
- gfrankeOct 22, 2020Aspirant
Gary
