msfixit111
Nov 30, 2020Aspirant
GS105 slowing down internet speed
I have a 5 port switch connected to my pc, VOIP (phone), homeplug (wired ethernet), and wireless router. My internet download speeds are running at about half of what they should be (compared to w...
msfixit111
Thanks for the explanation on the switch lights.
Yes, around 92.5 mbps (download) and 26.6 (upload). The download speed was upward of 200 mbps when I connected directly to modem (without switch).
I wish this picture I uploaded would display here but so far nothing. It shows my setup.
schumaku
Nov 30, 2020Guru - Experienced User
So what is connecting to the port showing the 100 Mb/s link only? Suspect something in the data path between computer and the Internet - thus the "slower" speed...
Try a different cable - Gigabit (both LED on) requires four working pairs.
The mods are always working on allowing in-line images. You could add it as an attachment if you are in a hurry.
