jdsolo
Nov 14, 2024Aspirant
GS105 Troubleshooting Low Upload Speed
Installed a new GS105 switch. Fiberoptic into house to router, connect router to switch. Laptop gets 900 Mbbs download / upload when hardwired via network cable Desktop gets 750 Mbbs downl...
- Nov 14, 2024
Problem solved.
Disabled the Killer app software that Dell loads. Once removed, speeds are back to full down and up (800 Mbbs for both).
schumaku
Nov 14, 2024Guru - Experienced User
jdsolo wrote:
Desktop gets 750 Mbbs download / 5 Mbbs upload when hardwired via network cable.
So issue appears to be desktop computer.
Of course, yes. Time to update the network adapter drivers
jdsolo wrote:
If I disconnect cable on desktop and use via Wifi, I get 350 down / 350 up.
Soon time for some more decent WiFi client, Wi-Fi router and/or access point tech?
- jdsoloNov 14, 2024Aspirant
Appreciate the input. After taking switch out of the equation (desktop directly to router), can confirm the desktop networking is the issue.
Desktop is from 2019. Updated all drivers from Dell site. Restarted, but still have same issue with decent down / up on wifi and excellent down / poor up (5 Mbbs) hardwired.
Do you think a new network card would solve the issue? May give that a shot.
Problem solved.
