PTAa
Jan 17, 2023Aspirant
GS105 v3 issue
Hello group, My GS105 v3 switch behaves oddly. The switch has three connections: - Port1: 1000 M cable to the fiber router with Internet and IPTV subscription - Port2: 1000 M cable to the IPTV...
Jan 17, 2023Guru - Experienced User
Does the problem travel if you use the other ports?
Possible that this device maybe inducing some odd signals.
Try a different switch to see if the problem follows or not.
PTAa
Same for all ports.
I also tried it with my FS105 v2, same results.
But the WiFi Plus access point from the IPTV provider handles it well.
Apparently, it does not happen so much when I use a streaming channel.
If it is real-time channel, it is bad.
If I select the Open LogFire channel, is breaks down completely.
That channel has a lot of motion in the picture due to the flames, so the traffic is high.
P-T
- PTAaJan 20, 2023Aspirant
No ideas?
P-T
