thezim
Sep 27, 2016Aspirant
GS108 Letter of Volatility
Hello, I need to get a Letter of Volatility for the GS108 series of Unmanaged switches. I found an earlier posting here (https://community.netgear.com/t5/Unmanaged-Switches/GS108v4-Letter-of-Vol...
- Sep 27, 2016
Hi thezim,
The GS108-400NAS corresponds to the GS108v4 for the region of North America and Latin America. You may check it here: GS108v4 Data Sheet.
You may download the Letter of Volatility for the GS108v4 here. The link will expire within 1-2 days.
DaneA
NETGEAR Community Team
DaneA
Sep 27, 2016NETGEAR Employee Retired
Hi thezim,
What version is your GS108 switch? Kindly check the label of your GS108 switch.
DaneA
thezim
HI DaneA,
I am really looking to purchase a new switch, and want to make sure that the new switch I purchase does not have any non-volatile memory. Most of the products that I see advertised are GS108-400NAS, but do not list "v4" or anything similar. Is it possible to get a Letter of Volatility that will cover all of the GS108 switches? If none of them have the ability to store any data through a power cycle, then they should all qualify.
Thanks!
- DaneASep 27, 2016NETGEAR Employee Retired
Hi thezim,
DaneA
