rbd's avatar
rbd
Tutor
Feb 22, 2016
GS108 vs. GS208 vs. GS608
I can see virtually no difference in specs between GS108/208/608 switches. Is any of these actually a superior product, or does the vendor just charge twice as much for adding 'Business class' to the...
  • JohnRo's avatar
    JohnRo
    Feb 22, 2016
    Hi rdb,
    Yes, all PROSAFE line has a higher MTBF compared to the SOHO versions and it has a lifetime hardware warranty that is why the price is a little different. Performance should be the same though they may have different hardware and chipsets, the GS208 is the newer version of the GS608 you may consider it as a cheaper hardware update.
    Thanks,
ProSupport for Business
