rbd
Feb 22, 2016Tutor
GS108 vs. GS208 vs. GS608
I can see virtually no difference in specs between GS108/208/608 switches. Is any of these actually a superior product, or does the vendor just charge twice as much for adding 'Business class' to the...
- Feb 22, 2016
Hi rdb,
Yes, all PROSAFE line has a higher MTBF compared to the SOHO versions and it has a lifetime hardware warranty that is why the price is a little different. Performance should be the same though they may have different hardware and chipsets, the GS208 is the newer version of the GS608 you may consider it as a cheaper hardware update.
Thanks,
JohnRo
Feb 22, 2016NETGEAR Employee Retired
Hi again rbd,
You're welcome!
Any of the two should work fine, it is just the matter on how long you think you will need an upgrade.
Have a great day!
Thanks,
MelSam
Feb 26, 2016Aspirant
Hi JohnRo,
In one Netgear ProSafe GS108 8-Port Switch box, there's a picture / image that shows the words "Gigabit Ethernet" printed in white and orange, and it includes an orange line underlying the word Gigabit and flanked to the left of the word Ethernet. The words appear in the carton right above the 5th and 6th ports (from left to right). Also, in the same carton, at the bottom right there is a single blue label "Netgear Lifetime Warranty".
In another Netgear ProSafe GS108 8-Port Switch box, there's a picture / image that does NOT show the words as seen in the above para. Also, in the carton's right corner there are three black labels "Lifetime Warranty", "Lifetime Tech Support" and "Lifetime Nextbusiness Day".
Since both the Switch boxes indicate GS108 8-Port, what is the difference(s) between them? Please explain. Thanks.
- JohnRoFeb 26, 2016NETGEAR Employee Retired
Hello MelSam,
Welcome to the community!
The GS108 has a lot of versions - latest version now is V4 (not including GS108E, GS108P/PE and GS108T). The reason for the hardware revision is to improve and redesign the GS108 switch. Compared to the V1 model, the GS108v4 is now smaller and has simple design. Chipsets may have also been changed to have better performance, increased buffer size etc. The first one you have mentioned is either a V1 or V2 model and the second one is a V4 model (latest).
Let us know if you have more questions.
Thanks,
