Reimemonster
Feb 17, 2022Follower
GS108LP seems broken
Hi, It looks a lot like my switch broke. No matter what device I connect, the device does not get an IP address. It did work yesterday, it does not work anymore today. Example: Laptop conne...
Feb 17, 2022Guru - Experienced User
If you reboot the router and replace the cable between the router/switch does it work?
