jmrichmond
Nov 05, 2021Follower
GS116v2 and IEEE 802.3ad
I have an old 16 port net gear GS116vs ethernet switch that is several years old. My question; does it support the Link Aggregation Group protcol, IEEE 802.3ad ?? Thanks in advance for your help...
- Nov 18, 2021
Peggy75 wrote:
C1-C16 is a Netgear GS116v2 smart managed switch
No idea what C1-C16 means in this context - this would be a GS116E or GS116Ev2.
According to the fine Gigabit Ethernet Smart Managed Plus Switches User Manual p.51 ff.
Set Up Link Aggregation Groups
Note: Static link aggregation (port trunking) is supported on models GS116E, JGS516PE, JGS524E, and JGS524PE....
Note: The switch does not support IEEE 802.3ad Link Aggregation or Link Aggregation Control Protocol (LACP) groups but supports manual static LAGs only.
Peggy75 wrote:
... switch is Balance XOR (IEEE 802.3ad draft v1), this is sometimes called Round-Robin.
Yes, this is one of the modes to be used on a host for a static LAG.
https://www.downloads.netgear.com/files/GDC/GS105EV2/WebManagedSwitches_UM_EN.pdf
