lucas_m
Feb 09, 2022Star
GS305 Switch capping at 100mbps
I recently bought a little, un-managed switch for a simple use case. There is a first cable (CAT6, like all the others cable I will speak about) going from my Internet Router into the 5th port of th...
- Feb 10, 2022
Climp them off and recrimp on new ones. all it takes is one pin to be bad/sketchy to cause issues.
Its not usually the cable that's bad.
lucas_m
Feb 10, 2022Star
What do you mean by "redo-ing the ends" ?
