achancetocut
Apr 06, 2025Aspirant
GS305v3 fails to connect with Windows 11
I have connected to HP printer via Cat 5e that threads through the wall with Windows 10. With Windows 11 it is denied access, 'Offline' with a cable directed across the floor, it connects. How can I ...
Apr 06, 2025Guru - Experienced User
The switch would not be blocking anything if it's working normally.
And with this cable running across the floor connected to the GS switch in the middle with the Windows PC also connected to this switch doesn't work?
Be sure your using good quality LAN cable. CAT6 is recommended.
achancetocut
Apr 08, 2025Aspirant
Using a Tripplet cable tester verifies connection. Connecting to Swann system next to the prtinter works well
using Windows 10 also connected gets to the printer. Is it Netgear problem?
- FURRYe38Apr 28, 2025Guru - Experienced User
Any progress on this?
You'd have to try another switch to determine that.
