Craig-Brown's avatar
May 02, 2021
GS305v3 Ports
I understand that I need to connect the input from my modem/router to one port, and all outputs to other devices to the other ports. Which port (1-5) should I use for the input from my modem/router?  Does it matter?
  • >  Because there's nothing to say?
    For someone like me, who is ignorant of switches, etc., it would have been nice if the manual (such as it is) actually said that it doesn't matter which ports are connected to what device. Saying nothing is not the same as having nothing to say. Just because you are an IT geek doesn't mean everyone else is.
  • > I understand that I need to connect the input from my modem/router to
    > one port, and all outputs to other devices to the other ports. [...]
       Ethernet ports are bidirectional; there are no "input" or "output"
    ports.
    > [...] Does it matter?
       No.  When you read the product documentation for your network switch,
    did you find any suggestion that any of its ports behaved differently
    from the others?
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get some.  Read?
    • Craig-Brown's avatar
      Craig-Brown
      Tutor
      I suspected it doesn't matter, but the documentation is very sparse, and doesn't say anything about the ports.
      • antinode's avatar
        antinode
        Guru
        > [...] the documentation is very sparse, and doesn't say anything about
        > the ports.
        > [...] When you read the product documentation for your network switch,
        > from the others?
           So, that'd be a "No", then?
           Another possibility would be to run the experiment.
