achancetocut
Apr 06, 2025Aspirant
GS305v3 fails to connect with Windows 11
I have connected to HP printer via Cat 5e that threads through the wall with Windows 10. With Windows 11 it is denied access, 'Offline' with a cable directed across the floor, it connects. How can I ...
achancetocut
Apr 08, 2025Aspirant
Using a Tripplet cable tester verifies connection. Connecting to Swann system next to the prtinter works well
using Windows 10 also connected gets to the printer. Is it Netgear problem?
Apr 28, 2025Guru - Experienced User
Any progress on this?
You'd have to try another switch to determine that.
