Cilvaring
Nov 11, 2021Initiate
GS308P No connection UI
Hi there, I'm running into something strange with my GS308P. From the beginning: I connected it to my network at home (192.168.188.0/24) and it received an IP in that range. I then accessed the...
- Nov 11, 2021
You have the GS308P?
Its an unmanaged switch. it doesn't have a login/access.
I have no idea what you initially logged into to change the IP.
Nov 11, 2021Guru - Experienced User
Cilvaring
Nov 15, 2021Initiate
Hi plemans
Thanks for your reply.
I noticed that pretty soon after posting the question.
It turns out my flat mate has a GS108E hooked up to our network which I did not know and I connected to that.
Since I only saw the Netgear Logo I thought that must be the GS308P.
Well, all good now. Thanks again.
- plemansNov 15, 2021Guru - Experienced User
Glad to hear it!
