nguyenel
Feb 15, 2022Aspirant
GS308P on Mac OS Monterey
Anybody have issues? I am connecting 2 gigabit ethernet cameras from Allied. Within 10 min, the cameras get disconnected. (OS Monterey) I see that Netgear has another model GS308EP I want an unmana...
nguyenel
Feb 16, 2022Aspirant
I am using 2 Allied Mako G-125B. This problem arise also on a system that only has one camera.
last time I checked the LEDs in the front of the switch. they were ON. That tells me, that the switch is unstable and dropped the connection and then it came back. My software cannot recover from this issue.
I am assuming it's a drop because if I just restart my software, the cameras are working again.
I had different configuration (one or 2 cameras. Mac mini or imac but always on Monterey).
I am going back to TP-Link.
schumaku
Feb 16, 2022Guru - Experienced User
- nguyenelFeb 18, 2022Aspirant
Sorry for the delay on getting back to this:
They are ON and blinking but the cameras are not responding anymore. This, sometimes takes over 24h to happen. The cameras will not stop responding if they are in use. If they were in use and then we leave them idle for a while, while our software is still running, the cameras drop. Or so it seems... because i went back to check and the LED are ON and blinking... but the cameras are not responding inside our software. I then restart our software, which then reassociates the link to the cameras and it works fine. I do not have to power cycle camera or the switch.
I have no interest in working around this problem with Netgear on Monterey. I will just go back to Tp-Link which shows no issue whatsover. Thank you!
