devinv
Apr 08, 2021Follower
GS308P slowing connection
When I plug my cat5-e cable into my router I get 160mbps down, 40 up. When I plug the GS308P into the same port on the router, then my laptop into the GS308P, I get 70 down, 40 up. All tested and...
Apr 08, 2021Guru - Experienced User
You did try different ports on the switch and different cables?
That is an unmanaged switch so there really isn't any settings to change/manipulate on it.
It also has green/yellow led's to indicate what port speed devices are connecting at.
