Scorbutico
Jan 05, 2025Aspirant
GS308v3 unable to connect to websites
Apologies for the long explanation I have a BT Smarthub 2 -connection fibre to cabinet, copper to the house. A 'TP link' range extender in the kitchen/diner - anything logged onto this extensio...
- Jan 05, 2025
The GS308 is a non managed switch so wouldn't or shouldn't be causing any problems. Unless it's a hardware failure. Be sure to sue good quality LAN cables between the host router and switch and ethernet connected devices. CAT6 UTP is best.
Test ethernet connected devices with out the switch in the mix to compare results.
Try a different switch to compare results. GS108 is another non managed switch.
Jan 05, 2025Guru - Experienced User
