DDPAT
May 08, 2022Aspirant
GS308v3 will not connect to new phone adaptor
GS308v3 I can not find much information on my router. I had a Cisco phone adapter for years and have used it with this router for some time now. The phone adapter went bad and I was sent a new one. ...
DDPAT
They were not helpful they referred me to the ISP
DDPAT
It connects and works sometimes for a couple of days or a day then disconnects again.
Xfinity was very rude but did send me instructions in an email but I cant figure it out.
- plemansMay 09, 2022Guru - Experienced User
The GS308 is a simple unmanaged switch. There isn't any settings or anything else on it you change. Whatever the gs308 is connected to is whats managing the connection. So basically what router do you have? If its an ISP device, they'd need to help you with it
- DDPATMay 17, 2022AspirantI have instructions through ISP to open a port which I did but my service still is dropping out.
- plemansMay 18, 2022Guru - Experienced User
Again, not sure what help you expect on here. the switch you have doesn't have any settings. It doesn't do any traffic management. Its a simple unmanaged switch. Something else router/gateway/or the device itself is who you need to be contacting fo rhelp with it.
