DuckNet
Aug 07, 2024Tutor
GS324P Switch drops dead every few minutes
Finally tracked down the local network problems to the GS324P switch. Every few minutes all the connection lights on the switch go dark. The router port light that is connected to the switch also goe...
- Aug 19, 2024
From what I read on the support page I get 90 days of complimentary support. I assume that after that I have to pay? Really?
I looked at many posts on reddit and other social media. Seems this is the case. The warranty is basically useless. The GS324P has been replaced with a Cisco 110 series switch. Hopefully this will last longer than the netgear switch.
The netgear support webpage seems to be designed to WASTE MY TIME in an attempt to find a solution to a problem. This will deter me and everyone else from actually finding a solution. Especially if that solution is that the product is simply defective. The warranty is useless. Now the GS324P switch is just another part of the e-waste problem.
The corporate responsibility to produce products that will work for many years, save my time and minimize waste are not factors that Netgear uses when they design, market, sell and support products. Corporate profit seems like the only goal. Well that's not my goal. So we have conflicting goals here and that makes Netgear products not suitable for my use any longer.
Aug 07, 2024Guru - Experienced User
This happens with out any thing connected to the switch? Try testing with the switch and maybe just one ethernet connected PC to the switch and not connected to any router. If still happening, possible the power supply section with in the switch is going bad.
How long have you had the switch in operation for?
DuckNet
Aug 07, 2024Tutor
I left the POE devices attached to the switch because the other switch does not have POE.
When the link-lights goes out, the poe lights for each port and switch's power light stay on. The POE devices also stay on.
So I don't think it's a power supply issue. The power supply is internal to the unit so really nothing I can do anyway.
Bought the unit on 10/24/22. So almost 2 years ago.
After using Netgear products for years and years this is the first one that has had a problem. So I really can't complain.
