Chris_Chelt
Aug 17, 2024Follower
Gs324v2 Port
Hello everyone, I have just purchased a Netgear GS324v2 switch for my home network and I have set it up as I normally would by attaching the ethernet cable from my router to port 1 and then everythi...
Aug 17, 2024Guru - Experienced User
I use port 24 on mine, that way for connection and wall ID or device ID, one can use port 1 for a ID of 1. For sequencial ID naming.
If you don't use this then you can use port 1 for the connection to the host router. I don't think it matters when it comes to non managed switches. User preference.
