Chris_Chelt
Aug 17, 2024Follower
Gs324v2 Port
Hello everyone, I have just purchased a Netgear GS324v2 switch for my home network and I have set it up as I normally would by attaching the ethernet cable from my router to port 1 and then everythi...
RennaD
Aug 18, 2024NETGEAR Moderator
Hello Chris_Chelt,
Welcome to the NETGEAR Community! 🙂
You can use any port as input/uplink port to the router. There is no specific port assigned for this.
If ever your concern has been resolved or answered, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Have a lovely day,
RennaD
Netgear Team
