Craddman
Feb 06, 2017Tutor
GS605v4 issues
I have a GS605 switch that I have used sucessfully for the past few years. It was previously hooked up in a play room with an XBox, Wii & Moxi (DVR) connected. We recently moved so I obviously discon...
- Feb 07, 2017
Hello Craddman,
Welcome to the community!
You pretty much have isolated you issue and pointed our that whenever you use the GS605 it gives you a bunch or errors/issue. These model should not really affect your network unless they are bad, mostly caused by a bad power supply or a bad unit. You know that the GS605 is a passthrough unit only and there is not much to troubleshoot on. You can test it out by using a different power supply if you have one, or swap it to the location of the GS105. If this would not make any difference,we'll call it a bust.
Thanks,
JohnRo
Feb 07, 2017NETGEAR Employee Retired
Hello Craddman,
Thanks,
