Craddman
Feb 06, 2017Tutor
GS605v4 issues
I have a GS605 switch that I have used sucessfully for the past few years. It was previously hooked up in a play room with an XBox, Wii & Moxi (DVR) connected. We recently moved so I obviously discon...
- Feb 07, 2017
Hello Craddman,
Welcome to the community!
You pretty much have isolated you issue and pointed our that whenever you use the GS605 it gives you a bunch or errors/issue. These model should not really affect your network unless they are bad, mostly caused by a bad power supply or a bad unit. You know that the GS605 is a passthrough unit only and there is not much to troubleshoot on. You can test it out by using a different power supply if you have one, or swap it to the location of the GS105. If this would not make any difference,we'll call it a bust.
Thanks,
Craddman
Feb 14, 2017Tutor
I replaced the switch and the problem went away so that would indicate it was an issue with the switch. I just thought the problem popping up when it did and the fact that I (incorrectly) thought that switches rarely go bad, was a bit suspect. Thanks for the assistance. Most of my networking gear is Netgear so I may be back with other questions/issues.
JohnRo
Feb 15, 2017NETGEAR Employee Retired
Hi Craddman,
Thank you for the update. They do rarely go bad but still, there are some instances that they do. Feel free to post a new topic, the community is happy to help.
Thanks,
