far1's avatar
far1
Tutor
Apr 30, 2021
GSS116E - Firmware download file gone?
Hi All, The firmware file for the GSS116E file doesn't appear to be there.  If I have the correct link it should have been here: https://www.netgear.com/support/product/GSS116E.aspx#ProSAFE%20Plus%...
  • schumaku's avatar
    Apr 30, 2021
    The firmware (and mandatory bootloader) updates for various GSS models had been revoked because to many customers had upgrade problems, leading to inop switches. YeZ ?
ProSupport for Business
