RayIT
Feb 25, 2025Aspirant
How to see configuration of MS510TXPP — 8-port PoE+ Multi-Gigabit Ethernet Smart Switch with 10G Cop
Can you see the configuration in the Insight portal or do you have to connect to the switch with a cat cable? I'm not sure if this is unmanaged either
- Feb 26, 2025
RayIT wrote:
Do you know what is the default ip to interface with the switch?
192.168.0.239 is the default LAN IP, when I'm not wrong, there is a DHCP client active by default, so check your router/DHCP server.
A possible alternate approach is to use the Netgear Discovery Tool for simplicity.
RayIT
Feb 26, 2025Aspirant
No problem, thank you for your help.
schumaku
Feb 26, 2025Guru - Experienced User
- RayITFeb 27, 2025Aspirant
Thank you for the help.
