d_juergen
Apr 30, 2025Follower
circuit diagram for the MS510TXPP switch
Does anyone have the circuit diagram for the MS510TXPP switch? It's just a few capacitors that are broken, and then it would work again. Unfortunately, I can't see which ones I need to buy.
Maybe someone can help. Thank you.
- Circuit diagrams are proprietary information, owned by Netgear and their OEM. So the answer is no. - Don't understand why you are not claiming the Netgear limited lifetime warranty on your device - at least if you can proof you are the original customer and ownership. Head to https://my.netgear.com/ 8-)
1 Reply
- schumakuGuru - Experienced UserCircuit diagrams are proprietary information, owned by Netgear and their OEM. So the answer is no. Don't understand why you are not claiming the Netgear limited lifetime warranty on your device - at least if you can proof you are the original customer and ownership. Head to https://my.netgear.com/ 8-)
 Migliora le tue competenze con la Netgear Academy - Formati, certificati e rimani aggiornato con la tecnologia Netgear più recente!
Unisciti a noi!
ProSupport for Business
 Piani di supporto completi per l'ottimizzazione della tua rete e la tranquillità della tua azienda.
