MayBeYas
Sep 26, 2021Aspirant
How to set port mirroring for GS110TPv3
Hi all, I cannot find Port Mirroring setting page on https://192.168.0.239 Monitoring tab shows only "Logs". I tried log on as "NETGEAR Insight Mobile App and Insight Cloud Portal" but I couldn't ...
schumaku
Sep 26, 2021Guru - Experienced User
Hi Yas,
What is the GS110TPv3 firmware version in place?
Not sure this moment if (by mistake?) the port mirroring might be disabled if the device is Insight managed.
-Kurt
MayBeYas
Hi kart
Thank you for reply.
Firmware version is 7.0.1.20
"might be disabled if the device is Insight managed."
I thinmk so too. Insight seems to obstacle Port Mirroring because I used it two years ago.
Should I buy subscription to use Port Mirrorring? or Should I update the firmware?
Best Regards,
Yas
- schumakuSep 27, 2021Guru - Experienced User
Yas,
On the Insight managed swiches I have at hand, Port Mirroring is available from Insight (certainly from theWeb UI), but not from the local Web UI while in Insight mode.Start with putting up a current firmware to the switch from https://www.netgear.com/support/product/gs110TPv3.aspx -> Downloads
While I love Insight, just for a single switch it does not always make real sense.
Regards,-Kurt
