Amarcellin's avatar
Amarcellin
Port mirroring GS105E
Hello,
i need to monitor video stream on a network, so i'm looking for switch in 1GB with port mirroring. Network has VLAN too.
Is the device GS105E the right thing I need ? WHat is the difference with the v2 version ?
Thanks !
  • Hi Amarcellin,
    Welcome to the community! :)
    I would recommend you the GS105Ev2 switch which is one of NETGEAR's 2nd generation of ProSAFE Plus Switches. It supports port mirroring as well as VLAN.
    The difference between the GS105Ev1 and the GS105Ev2 is that the GS105Ev2 has new features added which are loop detection and automatic DoS attack prevention.
    Kindly check the GS105Ev2 data sheet here.  For more information about the GS105Ev2, click here.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi Amarcellin,
    DaneA
      • DaneA's avatar
        DaneA
        Hi Amarcellin,
        You're welcome! :)
        If ever you have further inquiries, feel free to ask.  Otherwise, if you have no further questions to ask, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
        Cheers,
        DaneA
ProSupport for Business
