wiredfence's avatar
Aug 16, 2026
GS316EP: Port mirroring fails to capture traffic between two ports isolated in their own VLAN
Setup:
I have two VLANs configured:
  • VLAN 1 (default): most ports, including my normal LAN traffic
  • VLAN 10: exactly two ports (Port 3 and Port 4), used for an isolated point-to-point link between my cable modem and router’s WAN port
Port mirroring is configured with sources = Ports 1, 3, 4 and destination = Port 16. Port 16 is a tagged member of both VLAN 1 and VLAN 10.
The problem:
Mirroring from Port 1 (VLAN 1) to Port 16 works perfectly — I can see all that traffic clearly on the destination.
Mirroring from Ports 3/4 (the isolated VLAN 10) to Port 16 captures nothing — not even a single packet — despite:
  • Port statistics confirming heavy, continuous real traffic on both Port 3 and Port 4
  • Port mirroring config showing all three ports (1, 3, 4) correctly listed as sources
  • Port 16 confirmed as a tagged member of both VLAN 1 and VLAN 10
  • Testing both untagged (tcpdump -i <iface> -n) and VLAN-tagged (tcpdump -i <iface> -n vlan) captures on the destination — zero packets either way, even during extended (60-90 second) active traffic generation
What I suspect:
Since VLAN 10 has exactly two ports and all traffic between them is essentially point-to-point, I suspect the switch ASIC may be using some kind of hardware fast-path/shortcut for this traffic pattern that bypasses the mirroring engine — but I can’t confirm this and haven’t found it documented anywhere.
Questions:
  1. Is this a known limitation/behavior of this switch (or its chipset) for isolated two-port VLANs specifically?
  2. Is there a configuration workaround (different VLAN mode, different port count in the isolated VLAN, disabling some hardware acceleration feature) that would make this mirror correctly?
  3. Has anyone successfully mirrored traffic on a similarly isolated VLAN segment on this or a similar NETGEAR model?
  • Wanted to follow up with final results and where I landed, since you both took real time to help troubleshoot this.
    StephenB — tried your suggestion of swapping VLAN roles (moving the LAN to the isolated VLAN, moving the WAN link to VLAN 1) to test whether VLAN 1 had privileged status in the mirroring engine. Ran into an unrelated snag getting there (moving the Management VLAN to the isolated segment locked me out of the switch GUI, since that segment has no path back to the internal management subnet) — had to revert before completing a clean test. But I did run one more direct test: added a third plain port to the isolated VLAN (no mirroring involved, just normal VLAN membership) and connected a separate laptop with Wireshark directly. Same result as mirroring — only broadcast/ARP traffic visible, zero unicast traffic between the two isolated-VLAN ports. That's now been confirmed independently across two different capture devices (Security Onion sensor + a separate Wireshark laptop) and two different capture methods (formal port mirroring + plain VLAN bystander port), so I'm confident this isn't a config issue on my end.
    schumaku — appreciate the SPAN/RSPAN/ERSPAN context. It sounds like what I'm hitting is a limitation of local SPAN on this switch specifically for a minimal two-port isolated VLAN, without the more advanced RSPAN/ERSPAN capabilities that would be needed to work around it on this class of hardware.
    Where I landed: Going with a passive network tap (SharkTap Gigabit Network Sniffer) installed inline between my modem and router's WAN port instead. Since it's electrically passive with no VLAN/switching logic involved, it sidesteps this limitation entirely.
    Thanks again for the troubleshooting help — even though we didn't land on a switch-side fix, the process ruled out a lot of possibilities and gave me confidence the tap is the right call rather than a workaround for something I misconfigured. Marking this as resolved on my end.
  • StephenB's avatar
    Not sure of the limitations, but I don't think port 16 should be connected to either VLAN.
    Since this is a pass-through connection you might try just mirroring port 3 (not both port 3 and port 4).  Every packet traversing port 3 is also traversing port 4.
  • schumaku's avatar
    schumaku
    You can't do that - the mirroring designation port must provide exact the mirrored port data - so the port where you collect all data mirrored in captive mode must never use any other purpose.
    That isn't possible on typical small switches with port mirroring only.
    Not aware any industry standard software does allow to operate port mirrring adata toghether with actiove production data.
    You want to emulate the SPAN port possibilities you might know from the "big boys" e.g. on Cisco enterprise switches, where you can tunnel SPAN data through a dedicated, independant (SPAN) data channel.
    Local SPAN:
    Copies traffic between ports on the exact same switch.
    Remote SPAN (RSPAN):
    Sends mirrored data across a dedicated VLAN to a different switch.
    Encapsulated Remote SPAN (ERSPAN):
    Tunnels mirrored data across Layer 3 IP networks to reach central analysis tools.
    Most common aplications require the SPAN (mirrior port) data on a dedicated port, not carrying any addditional prfoducion or other data on top, typical examples are:
    Network Troubleshooting:
    Engineers use tools like Wireshark on the destination port to inspect live packet flows, pinpoint latency causes, and diagnose dropped connections.
    Security Monitoring:
    Intrusion Detection Systems (IDS) and security platforms read mirrored feeds to spot malware signatures, scanning behavior, and unauthorized access attempts.
    Application Performance Management (APM):
    IT teams analyze transaction times and user data streams to ensure software applications run fast and reliably.
    Compliance and Forensics:
    Auditors record and review data streams to verify that systems follow data privacy rules or to investigate past network breaches.
  • Thank you both for the detailed responses — really appreciate the expertise.
    StephenB — you're right that mirroring both Port 3 and Port 4 was redundant since it's a single pass-through link. I've simplified to just mirroring Port 3.
    schumaku — good catch on Port 16 needing to be a clean, single-purpose mirror destination. I reverted it to a plain untagged member of VLAN 1 only (its original, working configuration), removed it entirely from VLAN 10, and confirmed via the PVID table that it's back to a proper dedicated mirror port with no other VLAN membership.
    Unfortunately, even with this cleaner configuration, the result is unchanged: mirroring from Port 1 (my normal LAN VLAN) to Port 16 works perfectly, but mirroring from Port 3 (the isolated two-port VLAN carrying my modem-to-router link) still captures zero packets on the destination — confirmed via tcpdump on the receiving end, both with and without VLAN tag filtering, over multiple 60+ second active-traffic test windows.
    For what it's worth, I also confirmed via port statistics that Port 3 has substantial live traffic flowing through it the entire time — so the switch is definitely seeing and forwarding the traffic normally, it's just not reaching the mirror destination.
    At this point I've tested: basic mirror config, VLAN membership on source and destination, tagged vs. untagged handling, and port count in the isolated VLAN (2 vs. 3 members) — all with the same negative result.
    If either of you has seen this specific pattern before, or knows of a firmware setting that might affect it, I'd love to hear it — otherwise I'll likely move forward with a passive network tap for this particular link, since the mirroring approach doesn't seem to be working here.
    Thanks again for taking the time.
    • StephenB's avatar
      Try reversing the VLAN - using that for the LAN network, and using the default VLAN 1 for ports 3,4.  Then see if the mirroring behaves differently.
ProSupport for Business
