jmleczko
Feb 02, 2024Guide
How to enable port mirroring/SPAN on a GS316ep?
Hello,
I have a GS316EP currently on Firmware version 1.0.3.4.
Browsing to the IP of the switch and getting to the management ui, across the top, I have the selections of 'Home', 'Switching', 'POE', 'Diagnostics' and 'Settings'.
Nowhere do I see anything to set up Port Mirroring under the main or sub-menus. Is this a feature that needs to be enabled prior to it appearing in the management ui? And if so, how?
TIA
Right after posting this, I found it. (insert facepalm here)
1 Reply
- jmleczkoGuide
