Amarcellin
Oct 24, 2016Aspirant
Port mirroring GS105E
Hello, i need to monitor video stream on a network, so i'm looking for switch in 1GB with port mirroring. Network has VLAN too. Is the device GS105E the right thing I need ? WHat is the diffe...
- Oct 24, 2016
Hi Amarcellin,
Welcome to the community! :)
I would recommend you the GS105Ev2 switch which is one of NETGEAR's 2nd generation of ProSAFE Plus Switches. It supports port mirroring as well as VLAN.
The difference between the GS105Ev1 and the GS105Ev2 is that the GS105Ev2 has new features added which are loop detection and automatic DoS attack prevention.
Kindly check the GS105Ev2 data sheet here. For more information about the GS105Ev2, click here.
DaneA
NETGEAR Community Team
DaneA
Oct 24, 2016NETGEAR Employee Retired
Hi Amarcellin,
DaneA
- AmarcellinOct 24, 2016Aspirant
Thanks for your feedback :)
- DaneAOct 24, 2016NETGEAR Employee Retired
Hi Amarcellin,
You're welcome! :)
If ever you have further inquiries, feel free to ask. Otherwise, if you have no further questions to ask, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
