MayBeYas
Sep 26, 2021Aspirant
How to set port mirroring for GS110TPv3
Hi all, I cannot find Port Mirroring setting page on https://192.168.0.239 Monitoring tab shows only "Logs". I tried log on as "NETGEAR Insight Mobile App and Insight Cloud Portal" but I couldn't ...
MayBeYas
Hi kart
Thank you for reply.
Firmware version is 7.0.1.20
"might be disabled if the device is Insight managed."
I thinmk so too. Insight seems to obstacle Port Mirroring because I used it two years ago.
Should I buy subscription to use Port Mirrorring? or Should I update the firmware?
Best Regards,
Yas
schumaku
Sep 27, 2021Guru - Experienced User
Yas,
On the Insight managed swiches I have at hand, Port Mirroring is available from Insight (certainly from theWeb UI), but not from the local Web UI while in Insight mode.
Start with putting up a current firmware to the switch from https://www.netgear.com/support/product/gs110TPv3.aspx -> Downloads
While I love Insight, just for a single switch it does not always make real sense.
-Kurt
- MayBeYasSep 27, 2021Aspirant
Hi Kurt,
Okay I will try updating firmware and using Insight.
Thanks.
Best Regards,
Yas
- schumakuSep 27, 2021Guru - Experienced UserPort Mirroring must bei available in pure local Web management while not linked to Insight, too
- MayBeYasOct 04, 2021AspirantTo all supporters
Thank you for your comment . and I’m sorry for late reply.
Finally I can use port mirroring function by Insight setting .
It was very complicated to setup insight registeration.
Anyway thanks to all supporters.
Best Regards,
Yas
