colinmrgan100
Dec 01, 2021Aspirant
Jgs 524 or jfs524
I have a router that feeds 2 ip boxes, and some cameras. Can I use the net gear jgs 524 or jfs524? What’s difference between them? Thanks
colinmrgan100
Thanks DaneA, so I just take a cable from router to fgs254, then feed my ip tv , boxes , cameras etc off it?
Will that be better than just off the router?
Everything will be quicker?
DaneA
Dec 01, 2021NETGEAR Employee Retired
Since the JGS524 is an unmanaged switch, its main purpose is to extend the local network to connect more devices via the LAN.
The recommended setup should be: router--JGS524--devices. The JGS524 is connected to the router. Devices such as IPTV, IP cameras, computers, printers, etc are connected to the JGS524.
DaneA
NETGEAR Community Team
