van_Velzen
Sep 18, 2019Aspirant
JGS516 blinking lights
My JGS516 Switch lights are blinking after I have installed ORBI Micro Router. It was working before Situation: 1 I changed the Internet Modem from a Router to a Bridge (turned of Wifi and Route...
- Sep 19, 2019
Suspect something wrong with the installation resp. the data path:
Internet <-> Modem/Bridge <-> Internet/WAN Port [Orbi Router] LAN Port <-> JGS516
Do not connect the switch direct to the modem/bridge and the LAN.
schumaku
Sep 19, 2019Guru - Experienced User
van_Velzen
Sep 25, 2019Aspirant
Yes, that was the issue, a real noob error.
I did:
Internet - Modem/Bridge - Switch - Orbi Router
When it should have been:
Internet - Modem/Bridge - Orbi Router - Switch
I think that was in the first lesson on networks I ever had.
I wanted the router in the livingroom as it is quite esthetic, now its locked in the cabinet with the Modem and the switch.
Thanks for the reply.
Kind regards,
Marco
