JVK1
May 27, 2023Tutor
JGS516 switch and port trunking with QNAP NAS?
I have a QNAP TS-453Be NAS with two ethernet ports, and I'd like to configure it for port trunking to combine them for faster access speed. I have the JGS516 unmanaged switch. From what I'...
schumaku
May 28, 2023Guru - Experienced User
JVK1 wrote:
Link to QNAP article that lists the accepted for trunking modes:
https://www.qnap.com/en/how-to/tutorial/article/set-port-trunking-on-your-qnap-nas-to-increase-the-bandwidth-via-802-3ad-protocol
No, this is not a list of accepted modes. Please carefully re-read starting from the title clearly stating "Set Port Trunking on your QNAP NAS to increase the bandwidth via 802.3ad protocol." title - it's an example for link between QNAP NAS and Smart Managed Managed Switches for switches supporting 802.3ad aka LACP LAG.
A much better example for this use case - shown with an unmanaged QNAP switch as an example, applicable to virtually any unmanaged switch in the market - would be Configuring Port Trunking with a QNAP Unmanaged Switch and a QNAP NAS
We did everything with QNAP QTS to keep things transparent and simple as possible. There is a LOT of information provided while initially configuring a LAG. This includes comprehensive information when the possible LAG settings are listed.
Said that, for an unmanaged switch, the ubiquitous selection is General Switch, and Balance-alb, perfect for an unmanaged switch like the JGS516.
The network trunking modes like balance-tlb and balance-alb are described in the QNAP QTS Documentation -> Network & Virtual Switch -> How to use and set up your Network & Virtual switch?
