chicagobakh
Mar 16, 2024Follower
JGS516v2 router backhaul issues
I have been trying to get a TP-Link Deco system to work over Ethernet backhaul and this switch appears to not allow it. Other signals (e.g., a laptop computer plugged into a separate ethernet port) ...
ReneD
Mar 19, 2024NETGEAR Moderator
Hello chicagobakh,
And welcome to the NETGEAR Community! 🙂
Can you check if setting up the TP link deco wired backhaul will also work with other unmanaged switch. What are the status of the leds on the switchport when the Deco device is connected? It will be best to open a support case so Netgear can investigate this further. Or more likely a limitation on Deco setting up a wired backhaul since it requires the satellite to be connected directly to the Main Deco lan port?
https://www.tp-link.com/us/support/faq/1794/
Have a lovely day,
Rene D
Netgear Team
schumaku
Mar 20, 2024Guru - Experienced User
Not chicagobakh if you don't mind - we have remote access to some customer environments with TP Link Deco systems, connected to unmanaged switches resp. ISP supplied router LAN ports. Afraid, I have no systems connected to the customer networks for capturing traffic. 8-)
