shilohinf's avatar
shilohinf
Follower
Apr 30, 2019
JGS524 LOV needed
Apologies for the duplicate request, but I'm needing the LoV for the JGS524. Thank you.
  • JohnC_V's avatar
    Apr 30, 2019
    Hi shilohinf,
    Welcome to our community! :)
    Here is the letter of volatility for JGS524. The link will expire after 48 hour period.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    JohnCarloV
    NETGEAR Community Team
ProSupport for Business
