Tallrocker's avatar
Tallrocker
Follower
May 08, 2018
Require multiple LOV for JGS524 series switches
I require letters of volatility for the following unmanaged switches:
JGS524
JGS524E
JGS524F
JGS524v2
Thanks for the help.
  • Hi Tallrocker,
    Here is the letter of volatility for the following unmanaged switches. The link will expire after 48 hour period and no password needed.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
1 Reply
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi Tallrocker,
ProSupport for Business
