Tallrocker's avatar
Tallrocker
Follower
May 08, 2018
Require multiple LOV for JGS524 series switches
I require letters of volatility for the following unmanaged switches: JGS524 JGS524E JGS524F JGS524v2 Thanks for the help.
  • JohnC_V's avatar
    May 08, 2018
    Hi Tallrocker,
    Here is the letter of volatility for the following unmanaged switches. The link will expire after 48 hour period and no password needed.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
