lkeener225
Jul 20, 2020Follower
Multiple Switches
Can I connect multiple GS605 switches to one network? I upgraded my cable desktop box and the box requires an ethernet connection to recieve a 4K signal. The Cable router is about 25 feet from the location and already has a GS605 switch connected to it.
It should work just fine without any issues as this switch is just a plug and play unit. As long as it is under 100m standard distance of an ethernet cable.
Welcome to our community! :)
John
NETGEAR Community Team
1 Reply
- JohnC_VNETGEAR Employee Retired
John
