lkeener225's avatar
lkeener225
Follower
Jul 20, 2020
Multiple Switches
Can I connect multiple GS605 switches to one network? I upgraded my cable desktop box and the box requires an ethernet connection to recieve a 4K signal. The Cable router is about 25 feet from the lo...
  • JohnC_V's avatar
    Jul 21, 2020
    lkeener225,
    It should work just fine without any issues as this switch is just a plug and play unit. As long as it is under 100m standard distance of an ethernet cable.
    Welcome to our community! :)
    John
    NETGEAR Community Team
ProSupport for Business
