ewanpugh
May 04, 2022Follower
Loopback on 10G port on GS110MX switch
Hi,
I have an Unraid NAS with a 10Gb card connected to one of the two 10Gb ports on my unmanaged GS110MX switch. When I try to connect to the NAS, it is very intermittent, sometimes it doesn't work at all. I looked at the NAS logs, there appears to be a loopback caused by the switch. However, when I plug the NAS into one of the 1Gb ports I do not have this loopback issue and the connection works perfectly. The problem seems to be isolated to just the 10Gb ports. Does anyone have any idea on how to solve this as my NAS is now only running at 1Gb speeds?
Thanks
1 Reply
- JohnC_VNETGEAR Employee Retired
Hi ewanpugh,
Welcome to our community! 🙂
This GS110MX is just a plug and play switch and there is no web UI in order for us to check the configuration. Try unplugging all the cables and just connect the NAS, 1 PC, and the uplink to the router and let's see how it goes from there.
John
NETGEAR Community Team
