Th3-0n3
Aug 27, 2022Tutor
Low internet speed problems with ethernet switch GS105 any help
I hope somebody can help me with this issue. I have an unmanaged switch model gs105 prosafe. My issue is that overnight the switch reverts to 100mbps but never goes back to 1gb. To my understanding t...
Marc_V
Aug 29, 2022NETGEAR Employee Retired
@Th3-On-3
By any chance are you using the original power adapter or atleast same spec'd adapter? But since it's only Port 1 having the issue have you tried connecting the router to a different port? or connecting the router directly to the switch bypassing the walljack?
- Th3-0n3Sep 01, 2022TutorI'm using original power adapter. Yes I had tried using different port. While also connecting the Ethernet switch directly to the router bypassing the wall Jack.
It works for one day at the full 1gb down. But the next morning only one light is one showing that is at rather 10/100mbps.
