FRoller's avatar
FRoller
Minimum DC voltage for FS105v3
I'm embedding a FS105v3 ethernet switch into a system and won't have the provided adapter supplying 12V to the switch.
I have +12V available but want to isolate the switch from other system components using the same supply.  I would like to put say +11VDC into the switch (thru a regulator off of 12V supply).
I would like to know the minimum required voltage for this unit.
Thanks for any info you can provide.
Frank
  • schumaku's avatar
    schumaku
    Frank,
    A little brainstorming about your plan:
    • Typical voltge "precision" of the small power bricks is somehwere in the +/- 5% or so under various loads.
    • The switches have always some kind of internal power regulator(s) on board.
    • What is the idea behind adding a dedicated regulator for the switch?
    • FRoller's avatar
      FRoller
      schumaku,
      Since the switch is using an internal +12V system buss with other instruments I wanted to add the regulator to provide some more isolation of noise from the switch getting into these other instruments.  But that plan has changed and now I may need to run the switch at 13V instead. I think I read another article on this site which said that 13V is ok.
      It would be cool if the datasheet had a voltage range specified.  I can't imagine I'm the only one that embeds these:)
      Frank
ProSupport for Business
