Joel_Kohnen
Feb 09, 2023Follower
Modbus Data Transfer
Hello,
I'm using a ProSAFE 8-Port Gigabit Switch with the type GS108v4 and need to know if it is able to receive modbus Packages and send them to another device does anyone know something?
- The GS108v4 is a dumb switch. It passes on whatever you feed it.
Modbus/TCP is very likely workable on Ethernet networks and switches.
- microchip8MasterThe GS108v4 is a dumb switch. It passes on whatever you feed it.
