bbloom96's avatar
bbloom96
Model GS105. Only one device will access the internet through the switch
At my office, there are only 2 ethernet ports in my space.  I need to add a 3rd device.  We are using DHCP.
I connected a GS105 to one wall port and connected my existing computer and it works fine.  When I connect the second computer, all the connection lights become active and the computer connects, but it states unknown network with no internet.  I spoke with IT support and they checked their settings and all should work.  We even tested putting an Asus RT-N12 router in place of the GS105 and both devices connect.
Any thoughts of what may cause this?
  • Obviously the Ethernet port is limited to two concurent devices (MAC addresses) - very common on ports configured as access ports. Talk to the IT people again...
  • schumaku's avatar
    schumaku
    • bbloom96's avatar
      bbloom96
      You were correct.  They determined that the port label on the wall did not match up with the switch port.  The port on the switch was limited to 2 devices.
      Thanks
ProSupport for Business
